Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 46 of 46
Thread: Hasbro Force-FX Obi-Wan ROTS
  1. #41
    So, has anyone made a tutorial for the Tim's Hasbro Obi-Wan conversion kit, or are we supposed to wing it?
    There's always a bigger fish.
  2. #42
    Jedi Master
    Obi-Dar Ke-Gnomie's Avatar
    Jul 2007
    Ontario, Canada
    1,578
    I'm pretty sure it's the same, except that you don't need to unscrew the emitter to take it apart.
  3. #43
    Thanks, Obi-Dar Ke-Gnomie. Today I started the conversion. Everything went beautifully. It was turning out to be the easiest conversion I ever did. (I would note, though, that there is not need to remove the inner metal sheath of the hilt. Once you remove the switchbox, de-solder the wires, and stuff them into the switch hole, the entire hilt will slide easily off the blade, leaving an incredibly simply plastic unit to deal with.)
    So I'm cheerfully putting everything back together, when I notice I can't get the insides quite far enough into the hilt. I'm trying to line up the switch holes, but they are short just 2 or 3 millimeters. I think, "I must not have cut the plastic case down far enough," then I look into the emitter end, and notice that the aluminum conversion kit is just 2 or 3 millimeters from inside end of the hilt. I figure it's just a tight squeeze, and try to force in father. Nothing. I try hammering it in. Nothing. It's far enough in so that I can put the pommel on and there's no noticeable gap, so I could just drill the the plastic case a bit to allow the switch box to be reinserted, but I'm planning on selling this and want it to be as close to perfect as possible. Has anyone else tried this conversion and had a similar problem? I'm attaching a couple of photos to show what I mean when I say it's just a little bit short of where it should be. Thanks in advance for any help.
  4. #44
    Meh. I just took the easy route and shaved a couple of millimeters off the top of the plastic case. Since there doesn't seem to be a tutorial for the Hasbro Obi-Wan conversion using Tim's kit, I'll try to put one together.
  5. #45
    Nice tutorial but i am also looking on doing this but i want to make it into a Hilt and Saber for one me to carry on my belt and the other to dual with. I got my Hasbro FX Obiwan Damaged but i got it for $85 and free shipping. Can some tell me what do i need to buy inoder to make this work. Thanks. Also here is the picture of the damage.
    There is no emotion, there is peace.
    There is no ignorance, there is knowledge.
    There is no passion, there is serenity.
    There is no chaos, there is harmony.
    There is no death, there is the Force.
    http://hoylestudios.webs.com
    http://www.alderaanbase.com
    http://www.rebellegion.com
  6. #46
    Jedi Master Kal El Rah's Avatar
    Jul 2008
    High in the hiltops of the SIMI Valley
    1,378
    Quote Originally Posted by Obi-Jeff-Kenobi View Post
    http://www.thecustomsabershop.com/Ha...-kit-P273.aspx
    and of coarse, the LED of your choice plus lens and holder.
    I'M JUST A SPY(LOL)
