corbin
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Tenric Starkindler
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by DARTHMONKEY1706
JONITUS WHERE CAN I GET A BUTTON LIKE YOURS
SHHHh.COrbin was working on some to supply on his site. check there.
also: the tutorial I got from one of the links on TIm's page has a graflex replica button that works....
Reality often interferes with what would otherwise be an idyllic delusion.
I showed my dad this thread and he came up with a good idea. Check this out. It would work great for the prongs on the emitter shroud if you bent them outward more and grinded them down to a more round finish.
http://www.radioshack.com/product/in...0&cp=&origkw=9 volt battery holder&kw=9 volt battery holder&parentPage=search
nah, that wouldnt be thick enough. have you ever seen how thick those ears are? theyre thicker than that batt holder is, for certain.
The Brotherhood Of The Sith
Go to your local dollar store, there are plenty of $1.00 kitchen utensils that can be cut and shaped with your dremel to make the fins.
i used a piece of stainless steel i got from ace hardware and made the pattern using the now defunct graflica sites patterns.
maybe it was a different place then. i know that after i got those patterns a short time after that that site went down. i thought it was graflica.
edit: i just checked and i guess it come back on again. its there. and the patterns are there. so cool for anyone wishin to get graflex patterns
very cool and helpful tut , thanks.
Did you forget about us? I know, I know, you're probably VERY busy.. but uhh.. how soon before we see another update? []
"Do you know how to use that thing?"
"Yes. The pointy end goes into the other man."
Jedi Knight
Updates to come as soon as I have money with which to buy more parts. Remember...I don't make hardly anything off these sabers...so my work progresses as I have funds available. Perhaps an update the weekend of May 6th and 7th.
...how will you know the light unless you have seen the dark? How will you know the good unless you have flirted with the evil?
