Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 85
Thread: Clone Wars Ultimate Lightsaber - How-to-wire guide
    eastern57's Avatar
    Mar 2008
    1,962
    Default Clone Wars Ultimate Lightsaber Sound Board - How-to-wire guide
    This is a quick, down & dirty wiring diagram for the Clone Wars Ultimate Lightsaber:
    A few things to point out first:
    - The light source is a ring of 9x High Brightness 5mm LED (3 Red, 3 Green, 3 Blue)
    - 3 distinct "sound fonts" (we'll call them: *ROTJ, *SITH, *HASBRO)
    - Similar the SW-616, the sound fonts match the three colors
    -- Green to ROTJ
    -- RED to SITH
    -- Blue to HASBRO
    - The board supplies +/- 100mA to the light source (only lights one color at a time). It's sufficient to "light" a Lux3, but just barely...
    - The default setting for board alternates between the 3 colors/sound fonts, on each activation, unless a "crystal" is used (in this order: HASBRO, ROTJ, SITH).
    - Separate PCB has three momentary switches - one per sound font. When one is held down, the board will only sctivate that sound font. When two are held down, the board will alternate between the two. In the saber, the crystals are what hold the momentary buttons down, if you're using the board in a custom, mom switches should be replaced with latching switches.
    - Clash/Swing sensor is located on "emitter PCB" (white cylinder).
    - Album of the internals (guts): http://s306.photobucket.com/albums/n...tern57/Hasbro/
    *ROTJ - Has the distinct ROTJ activation sound
    *SITH - Distince Sith activation/deactivation and hum (think Anakin & Ventress in the Yavin rain)
    *HASBRO - Classic Hasbro sounds in all it's crappy glory
    Color Coded wiring chart:
    White Dots:
    Yellow wire - common return for the 3 momentary switches (brown/white/red - switches don't have polarity)
    Brown wire - momentary switch that selects ROTJ sound w/Green LED/wire
    White wire - momentary switch that selects HASBRO sound w/Blue LED/wire
    Red wire - momentary switch that selects SITH sound w/RED LED/wire
    Orange wire - Clash sensor #1 (works with white wire)
    Magenta Dots:
    Red wire - Negative (-) for Red LEDs, activates w/SITH
    Blue wire - Negative for Blue LEDs, activates w/HASBRO
    Green wire - Negative for Green LEDs, activates w/ROTJ
    White wire - Clash sensor #2 (works with orange wire)
    Black wire - Negative from battery pack
    Cyan Dots:
    Black wire - Common Positive (+) for LEDs (red wire. green wire, blue wire). yes, I know it's black, but it's still the positive
    Red wire - Positive (+) from battery pack
    Yellow Dots: speaker connections (no polarity, doesn't matter which is which)
    Good Luck!
    eastern57
    Jedi Master
    FenderBender's Avatar
    Jul 2008
    Earth System - Rhode Island
    1,531
    Eastern, you said that it only supplies 100ma at a time to the light source, but is that without considering when a mom switch is depressed and lights more than one color?
    GET LATHED!
    So let me see if I grasp this....
    If I wanted to run this for sound only, with a seperate puck for the LED, I could remove all wires pertaining to the leds, leave the orange and white for the clash sensor, wire up the battery and speaker accordingly and finally wire a new switch to the one thats on the board and this should work in such a way that every time I cycle the saber on and off it will cycle through the 3 different sound fonts.
    Sound about right?
    wsoFB by Nathan Barnes, on Flickr
    Mar 2007
    San Jose / San Francisco, CA
    4,082
    It does sound right (although I don't have a board to confirm that)... but I will at least say... you COULD use the boards's LED leads for "accent" LEDs. Seeing as they are already there... not a bad way to go.
    eastern57's Avatar
    Mar 2008
    1,962
    Quote Originally Posted by FenderBender View Post
    ... but is that without considering when a mom switch is depressed and lights more than one color?
    It will not run more than one color at a time. Think of it as 3 modes: it will only run in one mode at a time. One Hundred milliamps is an average.
    Quote Originally Posted by Darth Leximus View Post
    Sound about right?
    Yes. But in addition to keeping the orange and white wires, you'd have to keep the sensor too - it controls both the swings and the clashes.
    My Guy - Always thinking! It's actually perfect for that!
    And just to be sure this Clone Wars Ultimate Lightsaber is the kit for $35 that has all the different little pieces you need to customize different sabers right? Cause I planned on buying one of those at some point and guttin' it.
    Quote Originally Posted by eastern57 View Post
    If you put more than one crystal in it, it will activate both colours. So both Blue and Green LED's will turn on if you have the blue and green crystal in it. At least that is how it is with mine.
    Jedi Master
    Jul 2008
    1,531
    Right, so then it should put out more power.
    GET LATHED!
    eastern57's Avatar
    Mar 2008
    1,962
    Quote Originally Posted by Clockwork View Post
    Really? I guess there's variants then. Maybe I missed something. I'll check again. Thanks, dude!
    Or supply each LED with less amperage. I will test it out when I have time to gut the saber
