can any one give me a thread on how to wire the hasbro speaker with all of the other wires so that it turns on with the same blade power on switch. thanx for the help[8D]
this is neymore, formorley marty123
Thread Index??? (below in sig)
Want to roleplay in the SW universe? Visit:
</center>
it not in there. and i cant find it anywhere in the forums.[]
EDIT: Nevermind... look closer before you cry wolf.
</center>
http://www.thecustomsabershop.com/sa...p?TOPIC_ID=389
ok this is what i found and i want to use the last diagram on this page can you help me understand it? seeing as how i have know idea how to do it? but in a way so that i dont have that flash when it clashes with another blade
That one is a clash version and there is no way around it without having a seperate driver or hacking the clash senor off and lose the clash sound too.
</center>
ok thats fine i can do with out the clash sound so what part do i need to hack off to do that... also can you explain to me how the wireing goes on that diagram i dont really understand it that well thanx for your help
If you follow the wiring from the picture of the actual sound board you will see how to hook it up. I believe that you just remove the clash sensor and then it should no longer flash on contact but you will also loose the clash sound effect.
Do-Clo
Don't make me destroy you...
Yup it pretty straight forward. There are two battery wires (the outer ones) and the middle one is the lamp wire. The lamp wire goes on a positive point then put a wire from the negative of the LED to the negative of the battery.
</center>
