hear that do-clo. guess we will takem to the local body shop to have them painted. thanx for the advice firebird its a big help.
is this the same paints we would use if it were matte finish? say, using a matte paint, and then using a cleargloss coat over that?
hopefully do-clo can help you on your prob. he really knows his stuff in electronics. if its electrical, he should know something that will solve this.
Firebird try pressing in on the battery pack and see it the problems goes away, if it does then the problem is in the battery pack or the contacts between the battery pack and the sound board. A small rubber washer like a sink drain washer or even an rubber o ring might just do the job.
Do-Clo
Don't make me destroy you...
It definately sounds like your problem is in the connections between the battery pack and the sound board. Do you have a voltmeter?, if so remove the battery pack and press on the batteries and pack while measuring the voltage, this might require an extra hand so you might want to draft some help. If the voltage remains the same without changing then the problem lies inside the saber which could be a loose wire or maybe the plug that connects from the sound board and the contacts pins is loose. If the problem lies in the battery pack you can remove the three philps screws on top of the battery pack and look for a pinched wire or for a loose wire.
Do-Clo
I figured a loose wire but sometimes finding it can be a real pain in the south end. It is very fustrating trying to trouble shot something that you can't see(lol) but I don't mind helping when I can.
Do-Clo
as i thought too. that lil wire is pretty small and can snap off easily if not handled very carefully when tearing it apart and reassembly. on my vader mr i cut the wires about a 1.4 inch from the switch. and then just resoldered the wires together. made it easier than tryin to resolder to switch contacts. and possibly burning up switch while resoldering connections. worked just fine on mine.
it sounds like to me, the wire was broken, only held on by the plastic sheathing. and was intermittingly making contact.
keep playin round with it and see how it works.
and also, did ya catch that added question about goin for the matte with a clearcoat gloss sealer on the boxes? what paint types that would be if we went with matte finish. also i just looked up about powder coating. a black powder coating on these would be cool too. i know a plac ein tulsa, its a biker shop place, and they do powder coating. do you think that would be an option to go with
