Originally Posted by
swear000
The graflex has a plastic housing in it. Once that is removed, you get a hollow metal tube which you can build any way you like. You could, for example, fill the entire tube with a wooden dowel with a hole drilled in the center to hold whatever blade you plan on using. Or you could even have some type of mount custom machined.
The blade holders in the shop are pretty sturdy and when used with a blade retention screw, will hold the plastic blades pretty well. That setup will allow you to have an LED and electronics.
