Jedi Master
Pros and Cons of LED and EL
Could someone please list for me the pros and cons of both saber types? I know the EL has a uniform glow but isn't as bright, but besides that I really haven't heard alot.
I would say the main differences that matter are.
Blade thickness - 1" led...3/4" EL typically
Uniform glow - EL has it..LED doesnt
Brightness - For the most part LED is brighter, you can get close with some colors.
another pro of el would be the ability to easily change blade colors. with led, you have to make a new hilt or put a new led in the hilt. with el, you just need another blade.
I would have mentioned that except with a white LED you can use colored film to change the color.
neat. i didn't know that you could do that. i saw a purple blade like that, but i didn't know about other colors. have you used the film before? how does it look?
They are both about the same durable wise. I have never had a customer say his EL blade went bad.
Youngling
What about cost? Wouldn't EL be more expensive than LED?
Jedi Master
what colors are the brightest for EL?
lime is the brightest
