Hello everyone. So, with help from my mother-in-law (see they are not totally bad ), I am making a jedi costume for Halloween. Everything is coming along well, but I have noticed that I have a problem with the sleeves and wanted to get some input.
For the outter tunic we used a generic karate uniform top. It fits great, but once I put the tunic and obi on... I can't raise my arms past shoulder before it starts pulling the tunic up from under the obi. Is this just a problem that I have to live with or are there some little secrets on how to avoid this issue. What we have done so far to try and minimize the problem is to tuck part of the shoulder under, similar to what has been described for the Obi Wan Kenobi tunic. It allows for a little more mobility and gives the tunic a litte more of a V look like some integrated tabards are on in. Pretty neat look I think.
The second part is with the belt and obi. How high or low should the obi be? I would assume that the belt should be worn at the height of a normal belt, but that puts the obi pretty low. This isn't a problem if you are a guy that has no rear end, but that ain't me. Is the belt to be worn a little higher than normal? From what it looks like on costumes that I have seen, the belt is kind of high.
Thanks
