Obi Wan, TPM saber brass bicycle valve adapter part DIY
I'm using a Presta valve adapter the same way that a bicycle valve adapter was used on Obi Wan's TPM saber but am not 100% sure what the thread size/pitch is that I should drill/tap. I'm thinking it's 8mm with .75 thread pitch. has anyone used this type of valve adapter in a similar way? If so, how did you mount it?
Awesome idea, but just out of curiosity, why couldn't you just tap the saber for the thread already on the valve?
Jedi Master
Jumping in a little late here, but I just picked up a few of those Schrader adapters myself. I dug around online and got three different answers for the outer thread size.
One site said it was .302" x 32 tpi. Another said it was a 1/16" x 27 NPT, and a third site said that it was 7.7mm x .794mm pitch.
I figure it's just easier to do exactly what you did, and just screw a set screw into it. If you can't find a 5mm screw, a 10-24 screw will fit in, but it will be just a little sloppy. You could use a dab of JB Weld to fill the gaps and hold it in. That's what I'll probably do.
It would be nice to be able to just tap the threads to the right size and screw it in, but I'm not spending a bunch of money on special taps, especially when I'm not sure what size it is, and might end up buying the wrong one.
That's what I said at the time. I was almost completely sure of what size was needed but... anyway, there's usually always more than one way to get something done.
