Well swear said I might try running it off the battery. I took that to mean wire the accent led in series with the battery to the sound board.
As for parallel, I hadn't even considered that, please tell me more.
Maverick
gauge
wire between 26-18 gauge I would think. Smaller the gauge number, the fatter the wire if I remember correctly. CF wiring guide may have some clues. I don't have a CF yet so I haven't looked into it extensively. I would most likely lean toward 18 since I have a tendency to use the fattest wire I can get away with.
Yes, the LED will drain the battery unless you put in a very small switch or another driver board. I am pretty sure the CF can be used to drive accent LEDs. Did you see Mad Hatters "CF4 10W with the Works - Video + Tons o' Pics"? It looks like he used a custom logic circuit to drive the accent LEDs. CF on one side of the battery pack and logic circuit on the other. There is probably a way of creating a simplified version of the circuit for powering your LED.
I have been Googling circuit schematics for the past several weeks looking for one that I can use for a PLI. There may be one to fit your particular application, I just haven't stumbled across it yet.
I'm using an Ultrasound V2 lol
Maverick
Oh, LOL no, my accent LED is green. The main led will be royal blue
And the shop has 1 quick connecter less than i need @_@
Maverick @_@
Li-ion
I just remembered that the Li-ion packs generally come with a PCB. That circuit has a LVC (low voltage cutoff) and should, in theory, cut off the power to the LED when the battery voltage drops below a certain point.
These connectors are another good option:
http://www.hobby-lobby.com/connectors.htm
I use ones called micro deans but since sabers can have extensive wiring, I direct connect wherever I can. I will try the 26 gauge wire since making more room in the hilt seems like a good idea.
Reason: connectors
Sith Warrior
the 4 aa pack that is made for mhs should fit in that space. just make shure it is the one that is made for mhs. I would go aa because of the longer run time
Time for a kirby dance
