Page 1 of 10 1 2 3 ... LastLast
Results 1 to 10 of 93
Thread: Finally building my first LED saber.
    Default Finally building my first LED saber.
    Hey folks. I'm finally making my first LED saber. It will have an Ultrasound V2 and a Royal Blue LED. This saber isn't an MHS saber, It's an older saber I got some years ago, in the EL era of lightsabers (insert spooky sounds in the backround). So I'm converting this saber to LED.
    I have a few questions.
    I've combed the forums for a very long time, absorbing all the endless knowledge that is contained therein. Now, I need some opinions.
    What LED type should I go with? Lux III? K2? P4 with a filter? Is a Lux V worth it?
    I've noticed that the lens holders and maybe the lenses as well are out of stock. Where could I find them?
    I need something to mount the speaker in. Does anyone have any suggestions on how to make a speaker mount?
    The inner diameter of this saber is about 1 1/8th inches. To my understanding, the AAA battery holder will fit, is that correct?
    Every bit of info you guys can give me will help a lot. Thanks for listening guys
    Maverick
    Sith Warrior Sairon's Avatar
    Sep 2008
    Calgary, Alberta, Canada!
    1,603
    I would go with lux 5 cause a ultra v2 can handle the power. and how about a render of your saber.
    such a fast response! I accidentally hit enter and posted this too soon before I was done. And when I post, there's already a reply
    Lux V huh? Hmm. I have an Ultra Anakin Ep III and at night I can barely see sometimes its so bright @_@ All I can see is the blade pretty much.
    As for saber renders, I already have them. Just a matter of getting them up
    Maverick
    Sep 2008
    1,603
    alright! anyways yes a lux 5 is worth it and I would go with a four aa or rechargble, but doesn't the people who made ultra board say that you shouldn't keep batteries in long because it slowly drains? I personly would go 4aa first and if you casn go rechargeable.
    Well rechargable might be doable. I have a pommel being made by a certain someone that's a replica of the original pommel for this saber, one that can hold an MPS insert. So I could use the insert that will hold a recharge port and simply use it as a kill switch for when I'm not using the saber.
    I don't know about the whole rechargeable thing. I don't know much about it. Plus I've never wired anything more complex than wire A goes to pad B. Plus I'd have to make a speaker mount that will allow the wires to go through it.
    It gets more and more complex as it comes together @.@
    Maverick
    Sep 2008
    1,603
    okay. and lenses are in stock
    eastern57's Avatar
    Mar 2008
    1,958
    Quote Originally Posted by Sairon View Post
    That's easily fixed with the recharge port and kill-switch.
    I would have to differ in my opinion on LEDs: I prefer Seoul P4s. The brightness difference is marginal, but the power consumption is considerably less. A two pack of Li-Ion 14500s should be nice & small AND offer a respectable run time (roughly +/- 1.5 hrs, depending on frequency of use).
    The hard part with converting EL to LED [IMHO] is fabricating a solid heatsink mount and getting the optics to play nice. If the inner diameter is only 1 1/8", it could also raise a few arse-pains. How long is the inside? How much space do you have to work with overall?
    EDIT: doh you guys are quick. Maverick, the best way to be MORE comfortable with electronics and wiring - is to just do it!
    Yes, you'll make mistakes, yes, you'll burn the crap outta yer fingies, and yes there's a possibility you might not be pleased with the result... but it's your first. Almost everyone that's made their own saber hilt isn't 100% pleased with their first...
    Ah okay. Gonna be tight then. Halloween is coming up
    I'll work on some renders of my saber.
    Maverick
    Sep 2008
    1,603
    it also depends how bright you want it. if a lux three is bright then a p4 with a lee filter will be a bit lighter, a k2 more, and a lux 5 blasts them all away if you are using blue.
    eastern57's Avatar
    Mar 2008
    1,958
    I'm talking about the colored P4s - the white with filters doesn't really do it for me. But yes, LuxV blues are wicked bright
