Any good at modifying cr123 holders? I made a pack so the 2 cr123 lithium-ion batteries were one right on top of the other. I had to get creative because the recharge port wouldn't work...for whatever reason. I made the holder so I could take the batteries out and them put them into the wall charger for..well charging. I got rhe 3.0V batteries so that makes 6 volts total plus I have read that they can actually store a bit more so we're talking between 6 - 6.4V total..If your not using a buckpuck or the proper resistor...watch out for the magic smoke.
Be careful when modifying the led kit battery holders and trying to shove it in a ribbed section! I ruined a sound board and melted a battery holder by "removing" some material. Worked fine out side of saber for the 2 minutes i tried it. Once inside worked for a like 30 seconds then shut down. Upon re-ignition some burnt pcb smell and melted holder. Beware. My electronics savvyness isn't all that high so I have no idea what caused that. I just wont take out that much material again.
"The Dark Side offers power for power's sake. You must crave it. Covet it. You must seek power above all else, with no reservation or hesitation." ~Darth Revan~
If even a little metal from the springs (or spring bases) of a battery pack touch the insides of the aluminum body of a hilt--it can all be over in seconds.
And people wonder why I'm such a stickler for Li-Ion cells over Alkalines. Protection from short circuits, over-heating, higher voltage per cell, better energy density, safer for the environment. *sigh*
But anyhow... yes--isolate ALL metal connections, you must. Or fry your saber like Greedo, you might.
Ah, so this is what happened when I had a smoking battery pack, I quickly yanked it out, snipped the wires and tossed it with the batteries in it.
I thought I had a loose wire or a soldered connection's heatshrink came off and touched something. Thankfully, this was just a resistored saber and didn't have a soundboard. I will now line the insides of my MHS sabers with electrical tape or something.
The last post is a picture of how I did it:
http://forums.thecustomsabershop.com...?t=5143&page=3
