Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 41
Thread: Upgrade MR Saber with Makoto's led design
    Sith Warrior Sairon's Avatar
    Sep 2008
    Calgary, Alberta, Canada!
    1,603
    I'd also love to see your setup Makotosai vs a Hyperdyne, also a turtorial in english would be awsome, (make a turtorial now! your sabers are the best I want to make one so bad!)
    Jedi Initiate annon's Avatar
    Aug 2008
    charlotte nc
    341
    welcome to the forum Makotosai
    Can the blade be removed with your set up, or is it permanent like a MR?
    eastern57's Avatar
    Mar 2008
    1,958
    Quote Originally Posted by Sairon View Post
    ...also a turtorial in english would be awsome, (make a turtorial now! your sabers are the best I want to make one so bad!)
    He already wrote a tutorial:
    http://album.blog.yam.com/Lightsaber&folder=3759206
    And I made a few in english:
    http://www.fx-sabers.com/forum/index.php?topic=13487.0
    http://www.fx-sabers.com/forum/index.php?topic=13553.0
    http://www.fx-sabers.com/forum/index.php?topic=13567.0
    You can make them yourself - it's VERY easy, you just have to have enough patience to suffer the test
    Sep 2008
    1,603
    Thanks Eastern, I hadn't seen thoses threads berfore.
    What would you use instead if you don't have the MR foamy diffuser. (pm me
    Im really interested in this project.
    Just from taking a gander around has anybody used/heard about these guys?
    http://www.kingbrightusa.com/categor...20Angle&page=1
    They say 50 degree viewing angle and 20 ma feeds the beast.
    "The Dark Side offers power for power's sake. You must crave it. Covet it. You must seek power above all else, with no reservation or hesitation." ~Darth Revan~
    Sep 2008
    1,603
    I'd say get an acount and see how much it costs. if it's cheap we should test it, but if it is too expensive I'd look for cheaper ones (by cheap I mean less than a buck each or a good bulk rate) (also if you do get an acount you shold list the prices here, like of the 5mm rgb's and any others)
    edit: I found a great site that has many different types of five mm leds for a great price and free shipping. http://www.ledshoppe.com
    Quote Originally Posted by Darth Vane View Post
    please i need to know if you can convert MRs to this. i would love to have my Luke ANH with your setup.
    hi~Darth Vane~
    Luke ANH ?
    just like that?
    Quote Originally Posted by annon View Post
    Hi Annon~
    The MR saber after upgrade isn't remove, because it need to duel.
    If I make the MR saber that can be remove, the saber will be not strong and need to break the surface to fix saber.
    Quote Originally Posted by eastern57 View Post
    hi~Eastern57
    Happy to see you in here.
    For tutorial in English.
    [GOOD JOB] Tto you.
    If you understand every parts of the MR saber and make lightsaber more enought, upgrade the MR saber is not very diffcult and expensive.
    But~~
    You will break your MR saber when you are not have experience of MR's disassemble.
    So, if you want upgrade your MR saber, you must try to build lightsaber more enought by yourself.XD~~~
    The LED is more bright more better in 5mm(dia.) and the angle of 45 degree is best in my side.
