Results 1 to 4 of 4
Thread: What else do I need?
    Default What else do I need?
    Okay so far my parts are:
    Style 4 hilt
    Style 4 pommel
    Style 5 pommel insert
    Ribbed Extension
    5" Extension
    Style 10 bladeholder
    Luxeon k2 kit
    Not sure which polycarbonate tube
    Im brand new and open to any suggestions you may have.
    Default good
    looks good. maybe long with the 5 inch extension but that may not be a bad thing. Are you going to have a recharge port? Other thing to consider is screws for accent pieces. They are totally optional. Covertec belt clip is useful for some people. All depends if you are going for a basic hilt that works or a more authentic movie/game/comic replication.
    Wow that's a long one. If you do stick with the 5" extension you will want the double ended male connector found with the center section parts.
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    You'll also need a blade retention screw to hold the blade in. The blade holder has to be drilled and tapped for this. You can do it yourself, or pay Tim for that service.
