I'm not sure these parts will all work. I was using the saberbuilder.com to play with some ideas visually that I had sketched out. I need to know if i use a screw on LED blade holder style 1 on top of a MHS choke style 1 short will there be enough room inside the choke section for the heat sink and wiring to go through? I'd like it to just be the holder, choke section, and hilt, no additional sections if possible.
This is a rough idea for the majority of it. I will do it slightly different but this gives you an idea.
