For starters, if your diagram is an accurate reflection of your wiring - your puck and LuxIII aren't connected to anything but each other.
Sith Minion
Look for threads that member Arm on Fire has started. He has a couple of very good diagrams that may give you some insight. His have a couple of more steps based on what he wired but that should help you out a bit. And I agree with eastern, you need to do something about your wiring schematic because you are going to get no where fast the way you have it wired right now.
Jedi Master
If the color coding in your picture is accurate to what you've done, you have problems.
You've got the wires going to all the wrong places.
Red is positive from your battery, going through the switch.
Black is negative return to the battery.
White goes to the positive on the LED.
Blue goes to negative on the LED.
Ignore the gray and yellow. They are used if you want to dim the LED with a pot.
Jedi Master
