The LEDEngine is a great idea. I plan on using it myself.
Why not use the LEDEngine RGBA with a ten position switch?
How does the brightness fair with the split current in the color mixes (RG, GB, RB, RGB)?
So, has anyone tried to match up an RGB (or RGGB or RGBA) LED with the board from the Clone Wars Ultimate Lightsaber? I just got the latter today, and am going to try to track down the LEDengin RGGB LED Eastern introduced, and order a rotary switch, as well.
Luxeon has some new lenses with holders for the Rebel including a 6 degree lens. I wonder if this will make them as good to have as the Seoul or Prolight versions.
Those new rebel Hex optics are for individual rebel emitters on a pcb or star - the Endor star is the tri-rebel. There ARE optics that fit standard Endor (tri-rebel) stars, but it's either to wide an angle (25deg) or the 181 color mixer, and those are huge.
Xwingband has a good, working solution for tri-rebels, but they're specially made and they're not the stardard Endor stars.
Is it worth the trouble when LedEngin has RGGB and RGBA LEDs available? I've just ordered one of each and am hoping to find a way to use them with the guts of my Clone Wars Ultimate Lightsaber. I wonder if the Luxeon lenses and lens holders sold here at TCSS will fit the LedEngins.
There's always a bigger fish.
The silicon emitter domes on the LEDEngine LEDs are a micron bigger than the holes on standard collimators, and unfortunately, if you force them on, when you remove them - the dome will come off before the collimator will.
