Results 1 to 10 of 11
Thread: Is it possible to combinate LED-Strings and Luxeon???
    Default Is it possible to combinate LED-Strings and Luxeon???
    Hi!
    I've made a few lightsabers some yeras ago, but without light effects.
    Now I want to built a saber, which is MUCH bighter than an EL Saber.
    I began to solder an 150 LED Strip like the one which Hyperdyne sells. My first Try is to use 5mm Cyan leds with a brightness of 14.000 mcd.
    But I think, that this won't be enough
    So I'm asing myself if it would be possible to combinate an 3 or 5 Watt Luxeon LED inside the hilt with the LED Strip inside the Blade....
    What do you think?
    Did anyone try it?
    Thank you alot.
    Nice greetings,
    Markus
    I haven't tried it but I don't think it would work.
    The blades need to be empty for the light from the luxeon to go up it. The LED stip inside the blade would block most of the light going up it.
    5,899
    It would just serve to make the base flair. The LEDs in it would certainly block it and make it difficult.
    RED LEADER Standing by!
    OK thats what I was apprehensived of...
    But a strong Flare near the hilt would be look very cool!
    Did anyone here any trys with selfmade LED strips?
    Which LEDs are the best. I think the best was 5 Lumen, diffus LEDs with an angle of radiation of 120°...
    what do you think?
    Quote Originally Posted by Bert_one View Post
    what do you think?
    It's been done...do a search for 'makoto tsai led blade' and you should turn up something.
    Default yed idid
    yes i did that the problem with that is you wont be able too do battle with that casue it might brake a few of those led & then you would have too replace the one that broke its a pane to do ,,,i like too put a good lux3 so it got a good flare on the bothom & true the tube & no other led in the tube that way i can do fight without fear of breaking led
    because 40 led in a tube make it easy to break
    but it make a good flare depending of the led you use
    Why would you want to have an LED ladder and an LED star in your saber?
    Prepare for major PWNage.
    Definition of n00b- Here.
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    And why did you resurrect this year+ old thread? You didn't really add anything to the discussion that hasn't been pointed out in other threads since then.
    I think the obvious answer to the question in the title is:
    Yes, you can make a string of Luxeons, but the power requirements are going to be enormous.
    Banned Sith Lord
    Feb 2009
    1,873
    omg...
