i googled acrylic cone and after rooting around a bit i found this
you might be able to hack off the tip and use some weld-on, or epoxy or somethign to attatch it to the tip of your saber
http://www.painfulpleasures.com/xcar...?productid=115
The lebret body piercing is a very small spike. It would not work out the way you want. Even if you cut off a small section of the round tip and attached the spike it would not be an even taper & wouldnt look right. I would suggest the good ol' roam the hardware store for ideas method.
Cain
***A man is known by the enemies he carries, so make the best ones you can.***
***Give me a decent foothold and I will move the world.***
Jedi Master
Hmm...
So where do the regular rounded tips come from?
Maybe you can find a plastic wine bottle stopper, or something similar?
The rounded tips are cast. Meaning they start out as a liquid and get poured into a mold, let dry/ harden then pulled out. You could always get it in liquid form, make a mold and cast it pointed. However, acrylic is very brittle. It works for our tips because the rounded surface lets it pass by or "bounce off" most surfaces. But if you directly hit the tip it will shatter. A pointed tip I fear would shatter at the drop of a hat as it tapers to a thin point and also sticks out farther than the rounded style. I could be wrong but in my opinion a pointed tip will only lead to a shattered tip, by inevitably hitting something and breaking off- this is all of coarse refering to an acrylic tip, for someone who wants to use it for moderate to heavy dueling.
Cain
Jedi Master
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by scaarmor
The rounded tips are cast. Meaning they start out as a liquid and get poured into a mold, let dry/ harden then pulled out. You could always get it in liquid form, make a mold and cast it pointed. However, acrylic is very brittle. It works for our tips because the rounded surface lets it pass by or "bounce off" most surfaces. But if you directly hit the tip it will shatter. A pointed tip I fear would shatter at the drop of a hat as it tapers to a thin point and also sticks out farther than the rounded style. I could be wrong but in my opinion a pointed tip will only lead to a shattered tip, by inevitably hitting something and breaking off- this is all of coarse refering to an acrylic tip, for someone who wants to use it for moderate to heavy dueling.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Oh. Oh I see.
Well, could I make it out of plastic or something? Why does it have to be acrylic?
I dont see any reason why it "has" to be acrylic. Made of rigid plastic should work just fine. I believe the reason they are of acrylic is because these acrylic half rounds are readily available, easy to find/get, and inexpensive. Tim can correct me if I am wrong, but I believe that is the reason...
Cain
It is..but I have on order custom polyc tips with a shoulder that sets into the blade a tad for an extra strong tip. They should be here in about 2 months.
