Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 31 to 40 of 52
Thread: FAQ
  1. #31
    Jedi Master
    Obi-Dar Ke-Gnomie's Avatar
    Jul 2007
    Ontario, Canada
    1,579
    Here's the link to the builder:
    http://dmstudios.net/demos/saberBuilder/
    And here's the thread where it was discussed:
    http://forums.thecustomsabershop.com...ead.php?t=4645
    It would be a good idea to read through the whole thread. There's some good info about what to do and not to do.
  2. #32
    Many thanks.
    That's a great tool. Makes the design process worlds easier.
    I'll start digging around the index thread too. There are a ton of questions when you're new to this type of tech. My current saber is old school neon blade tech. Way too fragile and no blade removal.
  3. #33
    But they light up excelent!
    Xwing has one and it just lights up fantastic.
    Reaganomics not Obamanomics
  4. #34
    The builder doesn't work when I follow that link. I get a 404, file not found when I try to visit http://dmstudios.net/demos/saberBuilder/
  5. #35
    Jedi Master
    Jul 2007
    Ontario, Canada
    1,579
    It's been moved here:
    http://www.saberbuilder.com/
  6. #36
    that is correct, that is the new link/home (domain name) for the Saber Builder
    just made these using it.. (its a fun little app.)
    Just waiting on some kind soul to submit renders for the NEWER (EST) parts available in the store.. or even the ones that Tim gave us teaser picks for..
    (or the design contest saber parts as well)
    thanks
  7. #37
    Jedi Initiate Obi-Ben's Avatar
    Feb 2009
    Columbus, Ohio
    403
    How do I install decorative or accent LEDs to my saber?
    http://thecustomsa.web133.discountas...opic.php?t=163
    It is very similar to wiring the luxeon LED with a different resistor.
    This link isn't working--is there an updated url?
  8. #38
    Lord Maul's Avatar
    Jun 2006
    Seattle area, Washington
    5,169
    Hmmm, I thought I fixed those urls. I'll get on that
    EDIT: All the links should work now.
  9. #39
    http://forums.thecustomsabershop.com/showthread.php?t=4957&highlight=accent+LEDs
    It looks like the text was changed without changing the hyperlink. Clicking brings up a bad link, but C&Ping works
    New Staff Design
  10. #40
    Lord Maul's Avatar
    Jun 2006
    5,169
    Okay, try it now.
