Page 2 of 12 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 118
Thread: Rep Comm
    Nice... Can't wait to see it finished!
    "The Force is my ally. And a powerful ally it is."
    been working on getting the bucket smooth for the past 2 days bondo, sanding, more bondo, more sanding, primer, more sanding, more bondo, lol anyway here is some pics.
    Still have a day or two of clean up before I can think about moving on.
    When you can't run, you crawl, and when you can't do that, you find someone to carry you.
    Ok Unless I decide to cut the vents out, the helmet is ready for paint.
    Jedi Master
    Obi-Dar Ke-Gnomie's Avatar
    Jul 2007
    Ontario, Canada
    1,578
    That looks great! Awesome job!
    Jedi Padawan strengthofrage's Avatar
    Aug 2007
    United States of America
    598
    Superb, I love it!
    "Run when you have to, fight when you must, rest when you can."
    Vecna's Avatar
    Apr 2008
    Basingstoke, Hampshire, UK
    35
    ooooooo thats pretty.
    Cant wait to see the lid painted
    Ok I figured I would cut some of the armor that needed pieces taken out.
    First the backpack, the directions call for a 4X4 hole in the back to get at the electronics, mine ended up being a little bigger but thats cool as it all still lines up.
    The front on the pack it said to just cut out the 2 pieces for the windows I
    went to the inside of the inside of the line to try and make the graphics line up right.
    Then it called for the middle of the shoulders to be cut out so that the resin pieces showed through (looks right to me)
    Test fit
    Ok now it is down to smoothing the edges to make them fit right.
    Still working away a little at a time, smoothing out all the edges and prepping the plastic for paint at the moment (long and tedious) could probably skip a few steps of sanding but I like how the edges are turning out. Here is a shot of my current mess
    Ok kinda in a holding pattern for now until Delta all meets up so I am still cleaning up armor for the most part. I did cut the top vents on the helmet (not gonna cut the bottom ones) but I have some more cleaning to do not the vents (when I sanded the inside of the vents I rounded the corners)
    I also heated the thighs and got them to fit my leg (KEEP THE HEAT MOVING)
    Wrap it
    and cool it
    Makes a difference (mine done on the inside My son's not done on the outside)
    That is as far as I am on the armor, so far.
