Page 11 of 12 FirstFirst ... 9 10 11 12 LastLast
Results 101 to 110 of 117
Thread: LED (makototsai style) Testing
  1. #101
    Jedi Initiate vargose's Avatar
    Jul 2008
    St. Louis, MO
    393
    Whoa. Lets keep our cool. No need for language. When we are slandered, we answer kindly.
  2. #102
    Jul 2008
    St. Louis, MO
    393
    Quote Originally Posted by Hasid Lafre View Post
    As for the mr board thing, I was thinking, 2 short led strips powered by an mr board, would be just about the same as 1 long strand on a board wouldent?
    Again it depends on how you wire it. I know Makoto has managed it. I am sure we can figure it out.
    If you wire the two strips in parrallel to each other it would be the same.
  3. #103
  4. #104
    Sith Warrior Sairon's Avatar
    Sep 2008
    Calgary, Alberta, Canada!
    1,603
    Looks good LeMoel.
  5. #105
    Any idea how Makototsai did this?
  6. #106
    Quote Originally Posted by Jedi Sleepy View Post
    Leds facing a quartz cristal?
    -Mars
  7. #107
    Sep 2008
    1,603
    Its a rbg accent led, with one of Makototsai's custom crystals.
  8. #108
    I'm back after some months. I made a "kid-safe" LED saber from the materials I had. Keep in mind this is just a very crude first model- that's why the blade is massive and the handle is a PVC pipe. The thing is literally designed to be a lamp you can hit people with (and it is for the most part safe, both for the victim and for the blade components- as long as you don't go overboard).
    The consistency of the LEDs when not in their PE foam sheath is very good. I know I've already mentioned this before, but I'd like to reiterate that everything I've ordered from Hebeiltd's American distributor has been nothing short of impressive. I recommend the 4.5 mm LEDs.
    Ore no kono te ga makka ni moeru!
    Shouri wo tsukameto todoroki sakebu!
    BaaaaAAAAKUNETSU!
    GOOOOODUUU FINGAAAAAAAAAA!
  9. #109
    Jul 2008
    St. Louis, MO
    393
    Where did you get a PE foam sheath?
  10. #110
    Quote Originally Posted by vargose View Post
    That's a fancy phrase for a white pool noodle
    BaaaaAAAAKUNETSU!
