I found these at my LHS for RC cars and used them in my MHS. Not as large as the ones in the store but not small enough for me to break them
They don't quite fit through a 1/4" hole, but they do fit in a 17/64" hole. I just installed one on BS#2, for the switch, and drilled a second hole next to the first one, then filed out the middle to create a slot. It fit in there just fine, with room to spare.
I just measured the ones that I have, and at the widest point they come in at 0.26". Maybe if you filed them down a bit they would work for you.
I like to use molex KK connectors. You can get them in 2 pin - up to 9 pin or more! I buy them at a local electronics supply store.
In this pic you can see a 5 pin connector - underneath is a 2 and 3 pin male plugged into a 5 pin female.
MC
