Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 59
Thread: Info about 10W LedEngin Green LED (A couple of pics)
    Couple of details.... guys, when I say hot I mean black car on a sunny day hot, not "ohhhh crap, something is gonna melt!" hot. I think, when I turned it off it had reached kind of it's max heat.... where the heat displaced equaled the heat generated. I don't think it would have gotten much, if any hotter. I could hold and use it easily, as long as I held the handle end and not the emitter. I was a little worried if the emitter was that hot the actual LED might be a lot hotter and I didn't want to break my new toy on it's inagural run.
    It's a LED Engin green, BIN unknown. I'm guessing it's the midlle bin. Mouser has it listed at 425 Lumens, presumably at the nominal rating of 700 MA. It's on a typical star base, except it has solder pads for each of the 4 LEDs seperatly. That is important, it allows you to get to each one individually. As ERV pointed out, that could mean uber-cool things for RGB or RGBA sabers!
    Voltage.... the rated forward voltage of the LED is somewhere between 12.8 and 15.7V with all 4 of the LED's connected in SERIES. To let me get away with a feasible battery pack, I have 2 sets of LEDs connected in series. Each Buckpuck drives only 2 of the LEDs, with a forward voltage of 6.4 to 7.85 volts. Well within the range of an 8 cell NiMh pack.
    The batteries themselves... fairly conventional. 8 Cell NiMh AA sized batteries, 2600 MAH. I'm using a flat 4 battery pack, and a square 4 battery pack like the ones from Radio Shack to hold the batteries. The two packs are just for placement issues... the sound board and my Op-amp Buckpuck controller are on top of the flat 4 battery pack.
    Link to the LED spec sheet:
    http://www.ledengin.com/products/10wLZ/LZ4-00G110.pdf
    Link to the MCPCB spec sheet, shows how you can solder to each LED inividually and run any series/paralel config you want.
    http://ledengin.com/products/appnote...CPCBapNote.pdf
    So... I'm only claiming 425 lumens on this one.
    Now, the next one... well, LOL I have some ideas. ;-P
    (How about driving with a CF at 1 amp, and using the Power Extenders to activate a buckpuck @ 1 amp for the second set?) 2 Amps @ 7.2V (Average FV for this) and you'd be putting out 14.4 Watts..... Booyah! Might need a fan for that, though. )
    Quote Originally Posted by LeMoel View Post
    man I wouldnt try a purple filter with 700 lumen led,it will just wash it out, ive tryed an led at 350-400 lumens and it just washed most of my filters out. You should purchase an R bin seoul like xwing has been talking about. 300 luemens, would be perfect
    What filters did you use?
    there are Lee filters that I believe would do good results.
    You know, some are ment for way stronger lights then leds.
    -Mars
    Feb 2008
    British Columbia ,Canada
    461
    I used a Luxeon endor rebel white, i think it was like 400 lumens, I tryed all the normal purple filters, medium purple,rose purple, magneta, deep purple. It made the darker purples look better but honestly if you want a good filtered purple I would go with the Seoul P4(240 lumen) or the Lamina Atlas led(270 lumen)
    use either the ultra blade or Tim's style or xwings nylon might look decent also.
    240-300 lumens is the best for filtering Ive found.
    But if you really want to make a purple saber I would go with the prolight RGB led, its a true purple. And its a full purple. Its as bright as a 3 watt I think its the best right no untill there's optics for the endor rebel RGB, here's some pictures
    Note : this is with a crappy diffusion blade that comes with the MR construction kit. the blade would be even brighter and fuller with an ultra
    http://i27.photobucket.com/albums/c1...s/100_1263.jpg
    http://i27.photobucket.com/albums/c1...s/100_1264.jpg
    http://i27.photobucket.com/albums/c1...s/100_1265.jpg
    I have a Cree Q5 (220 lumens?) and all I got was washed out purple... or not bright ennough.
    Maybe you're right. I should try lesser leds. lol.
    -Mars
    Heh, that's awesome. Glad to see that those LEDs I found turned out alright.
    Quote Originally Posted by TroyO
    How 'bout one of those 10W UV?
    You willneed a uv reactive blade where the blade will glow. Normally it will less than a luxIII filtered.
    Theres a discussion at fsxabers about this.
    Reaganomics not Obamanomics
    Jedi Knight Malaki Skywalker's Avatar
    Dec 2007
    Planet Coruscant (U.K.)
    845
    Quote Originally Posted by Zero Unit View Post
    UV is also dangerous, even with LED's...
    I don't know...
    Quote Originally Posted by Hasid Lafre View Post
    True, and I have read the thread over at FX with great interest. However, the 10W UV LEDEngine LEDs are about as bright as the current Royal Blue LED (750mW, I believe, for the K2), which means a UV reactive blade isn't entirely necessary, just one with a coating to block the UV rays (I like to keep my eyes too).
    Feb 2008
    461
    Quote Originally Posted by Marsupial View Post
    Well I get good results from the240-270 lumens, try the magical magneta lee filter #795 its good or decent, purple is just a tough color to acheive, I like the RGB purple
    Feb 2008
    461
    Now UV isn't Purple, Its a dark blue with a tad bit of purple in it, Now im not saying that it isnt a good color but its not purple
    check out my UV my practice saber with 10 5mm UV leds
