Page 14 of 14 FirstFirst ... 4 12 13 14
Results 131 to 137 of 137
Thread: 1000 lumens, 14 mm wide
  1. #131
    also the cree is alot smaller (lense is about 5mm) and the P7 is like 8mm so you can't use them... I'm about 99% sure I bought that item and it didn't fit.
  2. #132
    Default Check this out-P7 on two circuits
  3. #133
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    That's rather rude, bzylman.
    It sounds to me like he might have some sort of dental appliance in his mouth.
  4. #134
    Default A good way to try
    Create a circuit for the P7 with a good heat sync, using two CR123 batteries.
    Get that working good.
    Get your lightsaber set using whatever drive you want and wire in a LED at lower lumens to power a crystal chamber. Basically, replace the lux or cree or p4 with a lower lumen led and the same voltage. Get that working the way you want with sound, pulse, vibration motor or whatever else.
    Do a protected switch to power both on at the same time and the tricky part is to do a crossover to get the pulse to alter the current going to the p7. This is the part that I can't seem to find. You need to protect the soundboard from back chat. Thats also a tricky part.
    I think that will work better.
  5. #135
    Dec 2005
    Not of this Earth
    6,077
    It's called a heat sink, you're not synchronizing anything to/with it.
  6. #136
    Quote Originally Posted by Moordak View Post
    I guess Scotty hasn't come back in time yet to invent it for us.
    since someone already showed that there is Transparent aluminum I'll just say this:
    Yay for Star Trek Tech! :P
  7. #137
    Jedi Master Kal El Rah's Avatar
    Jul 2008
    High in the hiltops of the SIMI Valley
    1,378
    Excellent find BF.
    I'M JUST A SPY(LOL)
