Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 100
Thread: Jay-gon's Brass saber 2 & 3 (MR Sound/Lux III's)
  1. #21
    Jay it amazes me what you can do with them sinktubes. I dont have the patience to deal with it. I would do the reverse like on your custom.
    I have very good feelings the clamp one is gonna turn out extremo sweet.
    Reaganomics not Obamanomics
  2. #22
    lookin' pretty sweet so far, i love that brass with the silver. I can't wait to see these all done.
    If you refuse to bridge the gap, You will always be on the other side.
  3. #23
    Okay, did some more work today. My feelings about the results are somewhat mixed, though....you'll see what I mean in a bit. Now on to pictures!
    I drew up the window cut-out for the grip section, and put the tube i the vise on my drill press. It works out well, 'cause the table swings from side to side to aalow for easier access to the sides of the tube:
    I started out with the cut-off wheel on my rotary tool:
    I cut all of the straight cuts first, then cut across the corners, and the piece fell off:
    I'll hang on to that, it may come in handy sometime!
    I swapped out the cutting wheel and installed my side scrolling bit. THe "Human Milling Machine" strikes again!
    I did the first corner allright, but on the second one, the bit decided to jump out of the tube and skittered across it! AAARRRRRGGGHH!!!
    After some choice words and a few minutes berating myself, I calmed down and finished it off, this time using the cutting wheel to remove more material from the corners, and using the side scrolling bit to round them off:
    I put on the sanding drum and did a little de-burring:
    And then some filing to try and square everything up a bit more:
    I also used a rat-tail file in the corners to further round them off, and then used some well worn 400 grit paper to sand on the surface. I also test assembled it to be sure the parts are going to line up right:
    The grips line up in the window perfectly! Success! My only gripe is the chewed-up line on the tube....and all the scratches you can see in that shot that were left by the clamp the first time I slid it on there....I also have a couple shots of the saber with the clamp installed, but you'll have to wait until later to see those!
  4. #24
    Looks great so far, I loves it
    Sith Happens
  5. #25
    Here's a few shots of Brass Saber #2 with the clamp on it:
    You can see my screw-up with th rotary tool pretty well in that shot....
    and that clamp needs to be polished sooo bad...
  6. #26
    couldent you fix that some how?
  7. #27
    I'm going to try to sand and buff it out.
  8. #28
    Sith Acolyte DACOTA's Avatar
    Mar 2006
    966
    I absolutely love your brass sabers! Great job man. Your very inspiring.
    [EDIT] Whoot! 900 posts!
  9. #29
    Thanks Dacota. These are fun to do, but somewhat nerve-wracking, because the brass scratches easily when you're working on it.
    I had a slight change in plans, though. I was testing out the location of the clamp, and decided that where it needed to go would put it right where the screws go for the front sinktube adaptor. So I placed an order for two of the 5" double threaded extensions, and requested that Tim skim them down to 1.42"-1.43" like the rest of these. That'll allow for the clamp to go anywhere, and free up the 4 adaptors for use in 4 more brass ones in the style of my first brass saber:
  10. #30
    Gorgeous...
