Results 1 to 10 of 10
Thread: TCSS Custom Work
    Oct 2005
    3,521
    Default TCSS Custom Work
    Had custom work done by us? Post pics here to give others ideas of what we can do.
    Lord Maul's Avatar
    Jun 2006
    Seattle area, Washington
    5,169
    What was done:
    1) Emitter style 2 had three slots cut in it, similar to the ones on emitter style 4.
    2) Three style 1 claws were modified to fit directly onto the emitter, no claw mount needed.
    3) Double threaded hilt style 2 had three windows cut into it.
    eastern57's Avatar
    Mar 2008
    1,961
    Third (and hopefully final) version of my MHS. Plecterlabs CF v2.63, Lux3 R/O, two long-shaft tactile push-buttons (brown-activation, black-aux)
    Custom blade holder style #8. BTW, thanks, Tim, it worked out great!!
    go here for full album
    http://s306.photobucket.com/albums/n...57/MHS%20Hilt/
    blade holder 7 cut into a crown emitter
    If you refuse to bridge the gap, You will always be on the other side.
    Had a custom blade holder made. Combined Blade Holder 6 and the first MHS thin neck together.
    twitch.tv/sigfreda
    Mara Jade Blade holder and 7" Hilt.
    eastern57's Avatar
    Mar 2008
    1,961
    Modified BH #5:
    Default Custom Emitters
    Tim did 2 custom emitters for me.
    Here's the first one:
    Here's some pics comparing it to stock Blade Holder 8
    Here are some pics of it on a complete MHS saber
    Here's the second custom emitter ... this one is short so it can be combined with Choke Style 2 and keep the length the same as the Kenobi ANH saber.
    It's like Blade Holder 8 only shorter ... here's a pic next to the stock Blade Holder 8
    Here's a pic showing the length difference with Choke Style 2
    Here are some pics showing it next to an Master Replicas LE Kenobi ANH Saber
    I wanted to match the Kenobi saber on length from the choke point to the top
    Default Yoda Emmitter
    Custome machined bladeholder with powder coat.
    SWEET!
    J.
    TK/TB/ID 8286
    501st Pathfinders Lancer
    Carolina Garrison- 501st Legion
    Blue Ridge Base- Rebel Legion
    BlackDOG across the SW forums galaxy......
    Blade holder and ribbed section turned down (shaved to a bit smaller diameter) to accomodate pre-existing cowls.
    Blade holder reshaped slightly for visual effect inside emmiter-shroud.
    NOTE: If turning down a diameter on a part that is to be powdercoated, be sure to allow 6-7 thousandths of an inch for the coating. I made that mistake and ended up with a lot more work.
    It's not how you move your saber...
    it's how you move yourself.
