I have a cutting tool from my old 60's dremel that is basically a round metal ball with cutting edges. This allows you to bore a slight dished hole in your blade without weakening it. I don't use the 1/16 walled blades anymore except with a wooden dowel rod inside covered with reflective paper for daytime practice. The only blade I ever broke was one from Parksabers. The wire attached to the EL paper twists until it forms a very tight knot which caused the blade to fracture at that point. On good hit with a J-Lo blade and crack...there it went. Clean break about an inch above the plug connector. I decided to keep it to show others why Lori's blades are better. Tim makes his the same way, so since Lori has retired from blade making, we can still get the same quality.
Zhi-don Aquintas
XO RL Sunrider Base
Treasurer/Head Instructor
Lightsaber training OCSWS
Aye laddie, that they are. Given that I mostly use my sabers for dueling, a short blade is not an option. I like a 40 inch blade for that, given that I don't have a long arm reach and some of my students do.....[]
Zhi-don Aquintas
XO RL Sunrider Base
