Did the wiring schematic for combining the Corbin/TCSS 3W driver and MR sound disappear? Does anyone have that handy and could post it up here for general consumption?
it's gone again, can someone repost it so I can save a copy?
opps sorry about that, I will fix it.
Reaganomics not Obamanomics
a few questions on this set up. some iv got an idea and just need checking others no clue, been trying to find some of them in the theads to no prevail.
1. MR sound bords requier a Lacthing switch?
2. The corbin/TCSS driver acts as a resistor/puck?
3. Is there a limit to what LED and voltage you can run through the set up? (if it helps il be useing vaders bord) IE luxon V blue, 9v.
4. can these cards/drivers fit inside a 1.25 sink tube?
If any of you masters can either let me know, or point me out to a thead iv missed id be much apreaciated.
Many than
EDIT
have i made a boo boo, and MR cards also called FX?
Broken Wings, Gone but not forgoten. We will always remeber
I only has the added recharge port one, though there isn't much difference
I don't know...
the diagram shown usees 2 clash sensors. im asueming one for the sound clash and one for the light clash.
isnt there a way to wire it up just useing one clash sensor so that the blade will flash in better sync with the sound clash?
No, there isn't. There's a long explanation for that, but it has been tried and fries either the Corbin board or the MR or both every time.
And just reiterate what Eastern mentioned, if you missed it, MR soundboards CANNOT use any more than 6 volts. And a 9volt will not have a very good runtime with this set up, either. 6 AAA's will run a lot longer.
And my 1.25 sinktube saber thread is here:
http://forums.thecustomsabershop.com...ead.php?t=5052
Hold on Jay Gon. If im not confused, The Luke rotj and Mace boards swing clash works differently and are ok to use.
http://forums.thecustomsabershop.com...ead.php?t=5315
"The Dark Side offers power for power's sake. You must crave it. Covet it. You must seek power above all else, with no reservation or hesitation." ~Darth Revan~
just read up on that and your both right, i didnt mention i was useing a vader bored so i have to use the 2, tho for my misses saber that will be rather helpfull (shes more likely to go for the lighter sounds), thx to you both for your input
EDIT:
Is it the Corbin bord that drains the batteries even when not on? or the MR bord?
