Hi, I was wondering if the "Corbin Style" 1in. OD blade would fit a Lux 3 Luke ROTJ. It is a MR saber converted by Ultrasabers, but TCSS blade looks better than the Ultrablade.
So, does it fit?
Thanks in advance,
RebelJedi1210
So, does it fit?
Thanks in advance,
RebelJedi1210
It should fit fine.
No Malaki, that isn't true for all his conversion.
The preconverted Mauls, Anakins, Vaders, Vader to Anakin AOTC sabers will not fit a standard 1 inch blade.
The DIY Anakins, Vaders, Vader to Anakin AOTC sabers will not fit a standard 1 inch blade. The DIY Maul sabers do fit the one inchers though.
So, what about the Luke ROTJ?
Listen to Strydur you must. It will fit, Ultra uses a metal bladeholder for that model.
With a BFH-9000 anything will fit
You can always take some fine sand paper and sand the bottom of the blade if it is too tight.
