i found most of the information on the conversion of FX obi saber to be quite helpful.
i also found that when they said push out and it tough, wow, they werent foolin. Here is how i ended up doing them...i had to do 4, three as gifts and one for myself. after pounding two of them for hours.....
after removing the battery, i took a dremel sander to top edge of the inside of the hilt to break away the coating on inside. then with a flat head screwdriver i loosened it from the hilt. then took a pare of needlenose and prided it out. then everything basically slid out much easier. its still snug when everything placed back in so not to worry about loosining it up too much.
Hope this helps the headache of the next person that trys to just push it out. my hands are still recouping from the pounding.
