Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: My led saber
    Default My led saber
    Ok, I introduce you my LED saber:
    But look what happens when I attach da blade
    This isn't a polyC tube, I know. The lens I'm using is a 60º one.
    Is there anything else I can do to make the light go trought all the blade instead changing my blade to a polyC one?
    5,899
    Change your optics. 60 is way too wide. Try 5 or 10 degrees. The tube isn't really the problem at all.
    <center>
    www.dewbackwing.com</center>
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by xwingband
    I was really getting worried, check my tube:
    It's totally white.
    Where can I get the lens only?
    5,899
    Right from Tim in the shop, but since you are international that would probably be silly. The shipping would cost way more than the part itself. I don't know where to point you other than wherever you got the LED.
    <center>
    are you using a star 3 lux lambertian? if so, then get one right here from tim. aw i see xwing beat me to it.
    If it means a Luxeon 3W, the answer is yep
    5,899
    Well we can tell from the pics it's a star mount just from the shape. The easiest way to tell if you have a lambertain or batwing is the LED. If it round it a lambertian and a flat top is a bat wing. The ones Tim sell fit lambertains.
    <center>
    Ok, i didn't got ur point []. I added ya on MSN.
    Here goes a picture of the LED:
    Youngling vadeblade's Avatar
    Industrial Complex in Saxet
    292
    1
    Well, Based on the picture, it looks like there is no optics mounted at all. adersondasilva, you need to purchase optics to shoot the light up the blade. Five or ten degrees spotlight colminator lense, like what Tim sells.
    Also, hard to tell if the Luxeon LED is Lambertian or Batwing with the LED on. Take the LED out of the hilt, and take a picture of the LED from a side view with it turned OFF (please remember to use macro on the camera)
    Thanks,
    -V
    http://www.geocities.com/projectstm/lightsaber.html
    5,899
    No worries vadeblade. I talked to him on MSN. He has optics and it's a Lambertain. I assume he took the optics out to take the picture. The main problem is he's international and getting the parts are a pain.[xx(]
    <center>
