I recently bought a MR saber construction set, gutted it and made an rgb saber with pots using the MR board, prolight rbg, and mhs components. This board has a similar dimmer driver to corbins board and sound and supports a three watt lux. Also I once found, and can no longer locate a thread in witch someone tied a vader MR board to corbins driver using a fig. 8 electrical path in order to use both boards on one clash sensor.
My questions are posed to all and any gurus for input. What I want to know is can the construction set board and corbins board be tied together using one sensor in order to drive one of aces tri-luxes?. using corbins board for the blue and green and the MR board for the red and sound. If this would work stable, on 7.2 or 9.6 volts with a voltage diverted for each board, whats pots would work? and would the lock up button still be an option?,
