not sure where i should post this but i found this as i was searching for Christmas gifts.
I found this Multi-Color LED Lightbulb with remote.
* IR remote can turn bulb on/off and adjust colors, transitions, brightness levels
* 4 transition effects - flash, strobe, fade, smooth
* Access to 16 specific colors (including White, Green, Blue, Red, Orange, Turquoise, Purple)
* Fits into a standard lightbulb socket
* Input voltage: AC110/AC220V, 50-60Hz
* Bulb Dimensions: 4" length x 2" dia.
* Note: you must remove the plastic tab in remote control battery compartment before using
http://www.thinkgeek.com/gadgets/lights/831e/
would this work?
