Jedi Initiate
help, question about cf v1.2
hi, been havin problems with my v1.2 crystal focus almost since i got it, with any more then 5 volts to the board, it keeps igniting and retracting constantly till the voltage is down to 5 volts, ive checked all the connections and re did all connections many times but it still does it, tried several differernt config files as well with no luck. the battery pack i have going to it is 4aaa batteries, around 6v and id like to stick with that for now, so if any one has an idea what is causing it id appreciate your input thanks
What on/off button style are you using? This used to happen to me on cf v1.2 until I used the correct switch with the correct switch setting.
Refer to the v1.2 manual for the switch settings, which are for both polarities of a latching switch, and a momentary I believe.
It is more than likely you are using a momentary with a latching setup or vice-versa.
Jedi Initiate
im using a latching, push on push off on my graflex saber, and i have the config set for latching, it works fine when the voltage is under 5v but anything over and it constantly goes on and off till it has 5v or less, then it works fine
Did you try another switch?
If that doesn't solve it... are you sure the LEDcurrent is set to the right value for your LED? Speaking of which, what kind of LED are you using? A Luxeon V?
Jedi Initiate
lux 3 led, and ive tried different switches. tried the mr switch when i had it in my anakin saber and the red button push on off switch in my graflex now
tried different configs for current as well, starting with the lowest setting
its really wierd how it just wants 5 volts and works fine as long as its under, but anyting over and it just dont wanna go
think my next upgrade to my gralfex saber might b a lux v, or a k2 i want it brighter then it is
Jedi Initiate
thanks for the ideas novastar, but ive fixed it, under close examination on the board with a magnifying glass i found that a tiny tiny slag of solder was just barely bridging from the switch solder pad to a ground strip beside it, cleaned off the solder and has been good since
Jedi Initiate
thanks, it was really annoying not being able to have all fresh batteries in it, but now i can may even go to a 7.2v recharable soon
