Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: D-ring safety
    http://www.decalfx.com/carbon_3_titanium_sheets.html
    Theres a site that sells carbon fiber tape of 12x24in and up. Pretty cool stuff. They also have xbox360 skins. Hope this helps someone if they wanted any of the tape.
    Nice coincidence.. But, wouldn't it be better if it worked the other way around, so that the saber is in "safety" mode when it is hanging on the belt?
    Quote Originally Posted by Darth Lars
    The D-ring wouldn't be in position to block the switch if it were being used to hang the hilt on the belt. It's only when it's pressed up against the hilt body that it blocks the switch.
    I suppose if I flipped the switch around, I could have it where the D-ring could keep the saber from turning off, but you'd have to have the D-ring up against the body and it might get in the way of your grip then.
    Corbin
