Hey, Madcow could you elaborate a little more on what your doing with your mace conv. I, myself, am doing a mace conv with a K2, (hence why I asked the question)and if you could post diagrams or parts that I might need to do what you are doing. Thanks
Jedi Knight
Here's a link to my wiring diagram - I'll use a similar setup for my mace conversion. Just ignore the rechargeable battery etc.
http://rpetkau.photosite.com/~photos...4738635257.jpg
Save the file, and open it in a program that you can enlarge it.
As I understand it - the LED leads from the MR sound card switch the relay to allow the full current to the K2.
MC
Jedi Knight
Just to update: LED Supply now has High Current Blue and Green in addition to the white they carried before! K2's rock.
_________________________
'Your swords please, we wouldn't want to make a mess of things in front of the Chancellor.' -Count Dooku
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Firebird21
Please forgive my ignorance...
But what's wrong with just running the LED directly threw the Switch?
Then it will turn on and off with the S/B and run directly off the Batteries (and whatever resistors may be needed).
Only thing I can think of is that the Switch can't handle the load, but I figure it's got to be worth a shot!
To add to what James said, there is also the issue of having the blade swich off BEFORE the retraction sound. With the relay - it should act just like using the existing wires.
Here's a link to the 5v relays I just ordered.
http://www.allelectronics.com/cgi-bi...RE_RELAY_.html
MC
But, James, I was under the impression that a 5w cannot even be run off an MR sound board
