Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: White LED pics
    2 resistor-driven Seoul P4's in an unlit room.
    P4 Mr driven ultrablade
    flash then no flash
    no blade
    Purple tcss + Lee filter 704 lily
    Both tcss pinks
    Tcss light green + 2 Lee 100 spring yellows= tiger green gatorade
    "The Dark Side offers power for power's sake. You must crave it. Covet it. You must seek power above all else, with no reservation or hesitation." ~Darth Revan~
    Jedi Initiate vargose's Avatar
    Jul 2008
    St. Louis, MO
    393
    Seoul P4 white
    1000mA buck Puck
    4AA
    The Blade:
    34 inch thin walled polycarbonate
    Cellophane wrap inside
    Sanded outside
    Rounded tip with hole drilled into center of reflective aluminum disc
    See full description on saber here
    Jedi Master
    Obi-Dar Ke-Gnomie's Avatar
    Jul 2007
    Ontario, Canada
    1,578
    I was playing around with my Lee swatch book this weekend. Found some neat colors. Seoul P4 running on a 1A buck puck. Dual film blade. (2X Corbin film & 5' of gift wrap.)
    For comparison of brightness, all photos were taken with the same camera settings. (For those who are interested, f3.2, 1/30 sec, 400 ISO, no flash.)
    The Oklahoma Yellow is what I normally run in my brass saber. I find it's a nice, rich yellow.
    The Spring Yellow has a hint of green in it, and is a little brighter than the Oklahoma yellow, but paler as well.
    The Jas Green in person is the coolest lime green color. It's almost the color of Mt Dew.
    Although it's called Fuchsia Pink, it's actually a nice purple.
    There are more colors I'd like to try. Stay tuned. If you have any questions, PM me. Don't post in this thread.
    Edited to add another picture.
    Seoul P4 white-TCSS thick wall tubing... i wanted to make a single handed hilt...short as possible...so i had to put the switch in the end pipe cap to save space..im gonna shorten the blade too to make it more like a short sword or wakizashi blade. The spiked brass blade retention screw is actually from my tattoo machines...perfect fit, if not a little long, but easy to change, and individual style is a consideration.
    http://i21.photobucket.com/albums/b2...shinobiwan.jpg
    My Little SHINOBI-WAN ...John-Paul shinobi Connelly
    A lux III
    with a 4 AAA batt. pack
    CF soon to come
    With flash and light on.
    Without lights/flash on.
    Falling to the dark side,
    i have gone to far. Now sarrow
    sings softly and sweet. Will i be saved
    or forgotten like rest?-"Col-Vin-Lune"
    white k2 run off hasbro econ board with clear thick walled blade
    TCSS white difuser and 10 degree lens and TCSS color disc
    white k2 run off hasbro econ board with special white thick walled blade
    white p4 run off US 2.5 board with clear thick walled blade
    white p4 run off US 2.5 board with special white thick walled blade
    white p4 run off US 2.5 board luxIII overdrive with clear thick walled blade
    white p4 run off US 2.5 board luxIII overdrive with special white thick walled blade
    same white p4 as my last post side by side with the new White Rebel
    p4 on left Rebel on the right same TCSS white thin blade both have a freshly charged 3.7v Lion.
