Results 1 to 10 of 34
Thread: Green LED pics
    Oct 2005
    3,521
    Default Green LED pics
    Post pictures with Green LED's only please.
    3watt & TCSS diffuser
    Luke ROTJ Green Luxeon with TCSS Diffuser Blade ( Made by Hajime )
    " Mind like Water "
    Sith Lord Do-Clo's Avatar
    3,830
    This is a 1 watt Luxeon led with 5 degree optics with a Hasbro sound board and a luxdrive micropuck on the the output of the Hasbro sound board driving the LED at 3 volts with TCSS diffuser in a ploy-c blade
    Do-Clo
    Don't make me destroy you...
    1W Luxeon Green
    Hi greetings from Peru. These are pictures of my first saber. Cyan led and three clear celophane sheets as difuser
    Here with the second one and the MR led string ones
    Here with Artoo
    Bye
    Luxeon III 3 watt emitter led, no optics, 14mm side-emitting fiber optic cable for diffuser.
    Luxeon 1500mah K2, direct-drive from an MR Vader S/B:
    Green Lux III, direct drive off an MR Luke soundboard, 1" thin-wall blade with a double-wrap of Corbin film, and a full (8 feet) of Ultrafilm as well:
    Camera settings altered to make blade appear as true to life as possible.
    Sith Acolyte DACOTA's Avatar
    Mar 2006
    966
    Green lux 3 also, on/off latching switch with 9 volt direct power with resistor and a thick walled blade with single wrap of corbin film and the shouldered tip with 3/4 mirror.
