Sith Minion
how to secure LED blade to FX saber
I need some quick advise I was able to remove the blade from my Anakin MR saber I was just trying to make it removable, but was is the best way to make it a screw release like a parks saber I just want to be able to undo one screw and then remove it....
The BEST way would be to wait until Tim gets the Anakin conversions in. Not only would it be the better PolyC tube but would have the blade lock feature he has made so famous. not to mention replacing a ton of crap LEDs to one powerful Luxeon.
P.S. It would probibly be better not to double post these types of questions (I just saw the one over on the conversions thread). Dont worry, post it once and you will be heard, and if anyone knows the answers they will post them[]...
Cain
Sith Minion
I think I will be doing that but this would just be temporary
Almost anything you make to temporarily make it quick release would compromise the looks after you get the actual conversion-i.e. drill a hole to put in a bolt, then get the conversion kit and have a hole in the hilt all for nothing and wish you would have waited and not put the hole there. I would suggest waiting. I know that sound crappy, as I am waiting for them as well. But in the end you will be happier you did.
Cain
On the anakin just use a screw mounted through the hole in front of the bottom button and you will be fine.
Sith Minion
well my Anakin is done and My Vader is 99% done the only thing I am having trouble figuring out is how to secure the blade while keeping it looking orginal The Anakin was easy I just used the button behind the rabbit ears I put in a longer screw (carefully) drilled the correct hole in the blade and voila instant release pin but Vaders I am having trouble with any ideas??
use the thumb screw in the Emitter. it will stay Movie correct that way. Tim sells several choices to kee the length proper.
Sith Minion
yea but that screw is two short unles he sells that part with a longer screw..
I do order special length thumbscrews for the vader conversions. I have some that are brass that I dont need if you want one.
Sith Minion
would love one I can paint it silver untill I get one I can use..
