Youngling
is there anything i can do to fix it?
Youngling
wait... correct me if i'm wrong but aren't the mr boards only capable of putting out like 900ma? if the k2 wants 1500ma i'm WAY underdriving it right? or is the corbin driver boosting things back up to 1000ma or whatever? lol i'm confusing myself.
How have you got it wired up ? If you are just using the MR board for sound then its current requirements are going to be pretty modest, less than 100ma on average, its capacity to drive a luxeon isnt an issue at all.
If you are using the corbin board to power the led then it should run fine on the 4xaaa batteries. You arent powering the corbin from the mr board are you ?
Phil Higgins
Youngling
yeah its latching.... i really have no idea whats wrong here... is it possible that either the positive or negative wires leading to the driver might be loose causing the driver to "think" you turned it off, giving it the fade out effect?
