I would recomend not bypassing the fuse on the sound board, if you have a short in your wiring or led without the fuse it will just burn up the board. With the fuse in then if a short occurs then it will blow the fuse shutting of the voltage to the circuit thus in theory protecting the sound board. If you can not find a small fuse you can wire in a larger fuse just make sure that the amp rating is the same.
Do-Clo
Don't make me destroy you...
has the sound board really been that much of a problem? I'd been eager to use it but after reading this...I'm worried now.
A Jedi gains power through understanding; a Sith gains understanding through power.
