Youngling
Hope it's OK to revive an old post.
I was just curious if anyone had used the fibre-optic cable in a thick walled 3/4" blade with a luxeon and how it worked if so?
I've got 3 3/4" EL hilts at the mo and my train of thought is that this is may be a better way of lighting it than with a hollow blade and diffuser.
I like the feel of the hilts with a thick-walled 3/4" blade; I know the thin-walled one's are better for lighting, but they feel too flimsy and I can't imagine they stand up to duelling very well.
Youngling
Thanks for that Jay-Gon.
It looks pretty bright but not too even, as you pointed out. Is it using an optic and anything reflective in the tip with the setup you have there?
I may well do some shopping when I can next afford to and experiment a bit with this. I wonder if wrapping something translucent and semi-reflective like polyP would help at all with the evenness.
I'll certainly share how it works out as and when I do have a chance to do this.
Youngling
[EDIT - sorry-whoops, accidental double post...]
Reason: Duh! Accidental double post when browser slowed down.
Yes, there was an acrylic mirror in the tip, but no lens in the emitter. I had noticed the cable was brighter when the end of the cable was closer to the led. Lumileds has a fibercoupler made for using with optic cable, but I can't remember what size cable it would fit....it also didn't look like you would be able to use it with a removeable blade set up, either.
I've thought about trying to add polyp to that blade with the cable, but again, the biggest drawback to the size of cable I used was weight....that blade was heavy!
Youngling
Thanks again, Jay.
Maybe the weight factor would just be too much, then, but I'd like to give it some testing when I can afford to.
I know you've used 3/4" quite a bit before - have you found any other solutions to get an optimal combination of lighting and duelability with an LED? I guess it'll end up being one compromise or another - trial and error and personal preference and stuff.
Jedi Knight
Originally Posted by
WeirdoTransvestite
Lightwhip anyone?
damn beat me to it, someone seriously needs to do that though it kinda looks like someone already did
Jedi Initiate
At the big burning man lightsaber fight someone had made EL wire lightwhips... damn those things stung!
I gave up on using the optic cable for a saber blade when I started using the polyp or cellophane wrap for light diffusion...it got the same results and was a heck of a lot lighter. I found this a while ago and thought it might work if someone wanted to do a lightwhip with a permanently attached cable:
http://www.luxeonstar.com/item.php?i...o=FFLI-07-LL-0
It can only use 7-9mm cable, but it should focus more of the light from the led into the cable making it brighter. It works with lux I, III, and V leds only, though. I haven't used one though, because they don't make them for the larger dia. cable like I've got.
