LOL ... oh boy ... the things that people say lol. OK ... so ... I have a Hyperblade ... currently I have the updated V2 driver with the amplified sound card. I have a V1 Blue blade that is the original 3-piece blade ... and I have 2 other V2 1-piece blades ... a Green and an Amber. I also had the original V1 driver before Jim came out with V2.
1). First ... I have almost a dozen Luxeon sabers (not including my MR conversations) ... and none of them come close to the brightness of the Hyperblade. I know people continue to want to fight this, but it's just a fact.
More than a year ago I took comparison pics of a Blue 3-piece Hyperblade with the V1 driver and a 5 Watt blue and posted those pics ... and it showed very clearly that the 5 Watt blue only matched the Hyperblade for the first few inches of the blade ... after that it was no match. I will post these pics again for newer people.
About the pic shown with the Luxeon 3 Watt, the Stock MR and the Hyperdyne ... this pic was taken by Master Yoda ... and it has been under a little scrutiny. Other moderators of fx-sabers say that an angled shot of a luxeon 3 is something called the "magic angle" or something like that. And it makes everything look great. I don't know if this is true, but I know my pics are all taken straight on with light in the room. And they are as close to what I see as it can get.
Now, about the duelability of the Hyperblade ... yes those videos are real. Hasid Lafre - I don't know where you are getting some of the things you are saying ... but I would stop talking to whoever they are coming from because it's some false information.
If you are using a 3-Piece Hyperblade ... then it is VERY duelable. And the concept should not be that foreign to anyone who understands Physics and force. The board is in 3 sections and connected by wire. Simple concept ... it can absorb and insane amount of force because it's in sections ... it's not one straight board. Now ... that said ... yes those blades are expensive ... and I COMPLETELY understand someone not wanting to take the risk. I myself keep my Hyperblade mostly for show. Also, the 1-Piece blade board is obviously meant ONLY for show. Since it does not have the same loose connections ... it can be damaged more easily. The benefits of the 1-Piece blade board is that it hides the gaps and comes out more even ... at the sametime sacrificing duelability.
3). The sound ... yes there have been numerous complaints about the sound not being great. And Jim is currently in the finishing stages of what appears to be a new awesome sound card that will definitely impress and be a big improvement over what he has now. I will hopefully be able to get one of the first ones in the next couple of months and I will immediately take video and post it.
4). The run-time. It's true, you don't get alot of time out the Hyperblade. In fact ... I would say if I have my brightness set at 7 or above I am definitely getting less than 45 minutes of run-time. This is a problem for many and totally understandable. Because of current battery technology I think it will be awhile till Jim is able to increase the battery life. The Hyperblade requires ALOT to stay as bright as it does. And even with his MUCH larger 11.1 volt battery pack (which barely fits in the MHS ... in some cases it doesn't ... just a matter of luck) ... you are not getting a lot of run-time. And for some that is enough of a downside to turn them off to it and again, I understand.
Also, yes you can install the Hyperblade in the MHS (if you can get the battery to fit) ... and yes the blades are removable.
So, basically, the Hyperblade isn't for everyone. I am not bias toward it, I have over a dozen Luxeon sabers (including my MR conversations) and only 1 Hyperblade ... but I do enjoy it alot. It is by far more complex and much more expensive than my Luxeon sabers.
For those who are interested ... here are some pics:
This is the V1 Hyperblade w/ Blue V1 3-Piece Blade VS. 3Watt Blue and Stock MR Blade
http://img220.imageshack.us/my.php?i...vshyperqw3.jpg
This is the V1 Hyperblade w/ Blue V1 3-Piece Blade VS. 5Watt Blue and TCSS Blade
http://img210.imageshack.us/my.php?i...vshyperwm4.jpg
Close-Up of the V1
http://img209.imageshack.us/my.php?i...closeupui5.jpg
V2 Hyperblade with Green 1-Piece V2 Blade
http://img223.imageshack.us/my.php?i...sc01914ul9.jpg
The V2 at C4
http://img220.imageshack.us/my.php?i...sc02090tu9.jpg
http://img222.imageshack.us/my.php?i...sc02104cd1.jpg
http://img233.imageshack.us/my.php?i...sc02179rc8.jpg
http://img523.imageshack.us/my.php?i...sc02184ey5.jpg
http://img517.imageshack.us/my.php?i...sc02330rq7.jpg
V2 Hyperblade with the new Amber V2 1-Piece Blade (No Flash)
http://img78.imageshack.us/my.php?image=dsc02536wk2.jpg
Close-Up of the V2 Amber (No Flash)
http://img233.imageshack.us/my.php?i...sc02537zz6.jpg
V2 Amber (WITH Flash)
http://img338.imageshack.us/my.php?i...sc02538sk1.jpg
