i need to know where would i put the resister for the LED if i am going to make my saber quick change. the think is it will be attached to a soundboard so the set up on the site will not work with the resitstor by the the power switch cause everything is already wired. What i was thinking is to put the resistor on the part that will be the LED light and not the end that will be attached to the sound board . also i need to know which end is or should i put it ont he end that will not be part of the LED module and attached to the sound board negative wire i just want some info so if you could please help it will be rocking
