Considering they aren't made yet, they could be made to fit whatever setup we wanted. If the diameter of the thing was larger than the 19/32" flat spot surrounding the switch hole, then you wouldn't even see that area when it was installed.
If you wanted a replacement retention nut that was just taller, that would be a fairly easy thing to make I'd say. It would require the flat spot be milled on the hilt though, but it's an easy thing to have the shop do.
Corbin
