Results 11 to 20 of 34
Thread: White 5 watt Luweon
    It was to prove that the flashlight guys have a screw loose.
    Reaganomics not Obamanomics
    Thanks X-Wing, seeing as how the highest priced one was $24.50 I think I can live with that lol! So if I purchased either the Cree XR-E or Seoul P4 could I simply swap it out with the current 3 watt in my Mace and have it be brighter than a K2 or is there more to it than that?
    Mar 2007
    San Jose / San Francisco, CA
    4,082
    Depends on the forward voltage required.
    5,899
    Quote Originally Posted by Novastar
    Every LED is different but the "typical" is the same.
    So, yes Simi. It's just a swap and it should give you more since they are more efficient. Even at 700mA it puts out 170-180 lumens.
    RED LEADER Standing by!
    Please forgive me for all of the questions but I suck with electricity and you guys are AWESOME with techincal know-how. Would it be brighter than a K2 with the 5 watt relay?
    5,899
    Yes, the K2 when maxed is only 140 lumens. You'll be getting better battery life and easily a 40 lumen boost over the K2 (likely more).
    REALLY!?! WOW!!! That is probably the best news I heard all day. I can't believe it would make THAT much of a difference without having to wire any additional stuff in. Which one would you recommend then, the Cree XR-E or Seoul P4 or are both okay to use? Which ever one you suggest I'm going to end up buying two. I read a thread on how this guy made a Mara Jade replica from a MHS. The pictures very cool and I don't think that would be too difficult of a project to tackle. Thanks to all of you in advance for all of your help, I REALLY APPRECIATE IT!!!
    Mar 2007
    4,082
    Quote Originally Posted by xwingband
    How is a Mace MRFX going to power a Lux V.
    Even if it does... how will it survive the 7+ volts without frying (without a relay or whatever).
    5,899
    Nova, I wasn't talking about the Luxeon V.... and never was. I'm talking about a Seoul or Cree LED.
    They are quite the rage in flashlights because of their efficiency. They are in the same as Luxeon III's as far as running them. They take 3.7V typical and 1000mA Max. BUT they give a max of 240 lumens.
    Simi, use which ever. I haven't looked significantly at the ones I linked, but I'd examine the bin numbers he gives to see which is best. Some of those may be a "warm" white (we traditionally use cool) and the characteristics may vary a bit... that's what the bin numbers will tell us.
    EDIT: Ahh... I see. The topic started about the V but I diverged it. He asked what the brightest white he could use was. Barring the multiple die high wattage LEDs the Seoul and Crees are on top for Whites. they easily beat others and replace the III.
    I read the reviews from all 3 of your links X-Wing and I am going with the Cree P4 XR-E 7090. One of the reviews on it mentioned it had a slight purple tint to the LED and since it is going into a Mace saber that was an obvious choice. Upon reading I found it also runs cooler than a K2 so by that I'll presume I can use the same heatsink. Since the top of the LED is taller, where can I get optics and a holder? I saw the 3W Cree, Regulator, Reflector http://www.dealextreme.com/details.dx/sku.1447. That doesn't seem like it would work for this type of application though. Is there something from www.luxeonstar.com that I can use?
