Results 1 to 7 of 7
Thread: setting up a push switch.
    Default setting up a push switch.
    how do you set up a push switch in an led lightsaber not push on / off but one you push then comes back off again
    red leader moving in to attack position.
    A momentary switch you mean?
    It comes on only when you press the switch and off when you let go?
    Reaganomics not Obamanomics
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    I'm not sure exactly what he's talking about.
    You can't really "set up" a push button switch, you need to buy the one that does what you want, in the first place. It's not like you can wire it differently, not a single pole single throw switch.
    You need to buy a switch that is capable of the action you want, be it momentary (only on when pushed), or push on/push off.
    This Jedi Ranger has a name....Terek Kelrune. Don't forget it.
    Dec 2005
    Not of this Earth
    6,077
    Heh, just beat you.
    Though you explained it better, JR.
    like the ones in a hasbro lightsaber
    Dec 2005
    Not of this Earth
    6,077
    That's a momentary switch.
