Originally Posted by
Jedi-Loreen
I just put together a saber for a friend that used blade holder #3. You just need to drill your hole in one of the grooves, it's not that hard.
I wouldn't drill your hole till you screw the blade holder on, with the heat sink between it an the hilt, to see exactly where you want the blade retention screw to be. I like to put my retention screws in line with the switch, but you might want it on the side, or opposite the switch, it's up to you.
And don't put your hole too low in the blade holder, the higher, the better but not right at the very top.
