Youngling
As xwingband stated, it is very likely sideglow fiber optic cable is inside the polycarbonate blade.
Here is the comercial hype one supplier says about their sideglow cable -
"Utilizing a recently perfected production process called continuous casting, Sideglow solid cable can now give off brilliant color clarity and a continuous bright light transmission that was not possible in earlier solid CORE fibers. A CRYSTAL clear Teflon sleeve gives high intensity brightness along the entire length of the optic cable."
I think Saberology got their "Crystal Core" idea from the quote above.
http://www.geocities.com/projectstm/lightsaber.html
Hello,
I just googled some info on side emmiting fiber optics as I hadnt heard of it before. From what I gather it doesnt look as bright as LED but that might have just been the pics I saw. It also said "two standard diameter of 19.3mm & 25.5mm" unless I am reading my converion chart wrong, wouldnt that make them to thick to fit into the polyc tubes? I also saw that they need a generator to run, small it was but not near as small as it would need to be to fit in a hilt.
Edit- I just found a site selling it in 1/2" dia. so I guess you can find it thinner, but at $7.50 per foot not including the generator unit- FORGET THAT! Tim with his EL wire and Luxeon LEDs has the market cornered for brightness and affordabilty.
Cain
I understand the topic much more due to your explaination , thankyou .
I think that tim's price's are definitely the best when it comes to affordability and function . though I have never seen one . But I think his LED kit is exactly what Iam looking for for now . I just want something impressive and functioning , and the brightness of it can be brighter ,but it only needs to be enough to captivate the imagination of my 11 and 13 year old brother's . For me of course , Im less picky .I was'nt even thinking of having my saber being lit . simply a colored acryllic blade , because I think I would ruin it . But you never know . I just need to start .
Anyways thank you guys for elaborating on the subject for me .
I won a advanced light/saberology saber on ebay, and just got it Monday. I have to say that the hilt is what makes the saber. I'm really not all that impressed with my blade though. It't nice and light in weight and more of the width of a 3/4 el blade. Honestly, its not as bright as the MR FX conversion I had done from Ultra. There is really nothing inside the blade that differs from others I've seen. Just a mirror tip at the top and film around the inside. I'm not sure if there is something inside the hilt near the led to make a difference.
